Anandtech bench
Hmmm.
Anandtech bench
Hmmm.
oh, not satisfied I see
Single card - http://www.bit-tech.net/hardware/graphics/2010/12/15/ati-radeon-hd-6970-review/10 - 306W, adding another wont make 612W
You need to check that both PCI-E slots run at equal speeds when using two gpus, I know the GD55/65 do.
And he's buying a 6950, not a 6970.
Not really. A 2x pci x16 mobo will add quite a lot to the budget. There will be pretty much no noticeable difference crossfiring with one x16 and one x8 slots.
http://support.asus.com/PowerSupply.aspx?SLanguage=en
That calculator seems massively off then from what you are saying, it reccomends 950W for the spec I posted with crossfire 6870's...
Yeah, a V1 reference card. With the intention of flashing it to a HD6970.
What was your point?![]()
8x/8x is available in the GD53/55/65, all around the £100-130 price mark.
There will be a 1-2% max loss in framerates for these boards.
Again, failing to see your point?![]()
The point that a flashed 6950 uses less power than a 6970.
I'll give you this one![]()
But with the 700w PSU the OP has said he will be getting power isn't an issue![]()
