White sprit to remove cpu paste
  • Thread starter Thread starter Eric's collar
  • Start date Start date
Eric's collar
Eric's collar
Is this advisable ? I was planning to get some isoprophyl alcohol but I heard white spirit and some cotton buds do the job.
White spirit will leave a film behind. Get some iso or if you really can't find any, use the cheapest vodka you can get your hands on.
What on earth is a lint free cloth? Keep hearing it being batted around...
Is it just a cloth that doesn't leave bits behind?
And where can I obtain one? :p
There you go Link
Yeah it doesn't leave bits behind like clinging bits of fiber and fluff
Hope this helps :D
Just because you've done something countless times, doesn't mean it's a great idea.
The parafin it leaves behind impares the properties of the interface material.
Any residue that it leaves behind is going to be so minute that it's not going to make a measureable difference.
If you wear glasses then you can use the cloth that comes with your glasses case... although don't wipe your specs after cleaning your CPU ;)
I just used white spirit tonight to reseat my H50 with IC Diamond, have always used it with a bit of kitchen roll, temps are 33 -35 so i don't think there's any problem using it.
