OcUK Aphrodite Media Case
4 May 2011
Since updating to a new i5 system my old PC has been kicked out of its case and I'm looking for a media centre case.
So, has the included PSU got a 6 pin PCIe connector?
Will double slot graphics cards fit into the case?
Am I going to have any problems with fitting this into the case? (Height and width wise)
PC to go into the case:
ATX mobo (Abit Fatal1ty FP-IN9)
Artic Pro 7
Evga 8800GTS 320MB
Had a look around on the forums and found some pics of it. It fits the GPU and AP7.
Just need to know about the PSU now, whether it has a 6 pin PCIe.
If not, I'll be going for a Coolermaster 360 & Corsair Builder 430W unless anyone can recommend a better ATX HTPC case?
I highly doubt it has a 6pin PCI E cable on the PSU. I have bought a different OCUK value case that had come with a 500w psu which did not have the 6 pin connector. To be honest there is probably only 1 sata connector and its 3 or 4 4 pin molex connectors. Not bas for a budget build but if you have the money to spend i would highly recommend getting another PSU.
