- 4 Jul 2009
- Edinburgh mostly
I don't know exactly, but life is an illusion designed to keep your mind occupied while you are digested by God.
Well, that can be true, if you consider decomposition and recycling of the bodies energy back into the ecosystem to be a better cause
Scientific evidence for that please? The personality and soul are not forms of detectable energy, all the energy that an organic body does contain decomposes and recycles back into the ecosystem.
The entire post is, naturally, "my opinion", as could only be expected in such a loaded question as the topic.
That is very true; I felt I had to say it to you though. Nothing wrong with dying with an open mind. I think that's one benefit religion has actually brought segments of humanity..
Because philosophy and silly opinions like Dr Shulman's are purely daft thats why.
The massive amount of brain energy required for consciousness is, believe it or not, created by a working brain. When the brain stops working, the energy disappears, just like pulling the plug out of your PC.
You said in another post that the PC still has 'potential energy'. But that isnt the case with the brain, because after it is dead it is no longer working, hence it cannot reform your consciousness.
If you want to research or learn about consciousness, then I would strongly suggest that you study Neuroscience instead and learn about how the brain and its nervous functions and impulses actually work.
Heres a book that I strongly suggest you pick up and read:
http://mitpress.mit.edu/catalog/item/default.asp?tid=8595&ttype=2
You simply pulled that book out of googling "Conciousness" or something, hoping it supported your theory....![]()
I cba actually reading the whole argument & source (sorry) so I'll take your word, but isn't that absolutely priceless when people do that?
I wouldnt bother reading it tbh, it is the usual open v closed mindedness argument. Frankly I dont why I keep getting involved in such nonsense.
You've got a problem man. Seek help.
If you had joined same time as me, and posting at 32 odd posts per day like I think it was the last time I looked then you'd be sitting next to me with circa 100,000 posts.
You are approaching the life/wife losing territory![]()
I'll get bored eventually and then my DP tally will drop off a bit.
Make you a touch self conscious there?![]()
Was only playing, but you've hammered that through scarily quick.
not pysically, emotionally you're pesonaility soul what you want to call it is going to be used for something else, to its like the sun makes food right , we eat that food which is coverted to energy , that energy is not just how long you can go at work or something , its energy building up thats released when you die, i am pritty sure of this and there is a reason for it.
So you disagree that the Law of Conservation of Energy is valid then?
Against all the scientific consensus to the contrary.
Dr Shulman is hardly a man of silly opinions.
http://www.mbb.yale.edu/faculty/pages/shulman.html
I did not say it could reform your conciousness, all I said was that you should consider the law of energy conservation when you state categorically when conciousness ceases and that that energy within a living brain transforms into another state and we have no idea what that state is, we can theorize it changes to heat energy or whatever, but it isn't destroyed, it doesn't simply cease to exist, it ceases to exist in that particular form.
And a dead brain does have potential energy btw, quite a lot in fact compared to other areas of the body.
Sure, you obviously haven't actually read that book, otherwise you would know that a couple of the papers within it deal with the philosophical side of conciousness, that is the same philosophy that you call daft btw.
Bhavy did you read the link Castiel posted? It's actually a pretty normal article about standard science (well that's how I read it), doesn't say anything about what happens after death, no idea where castiels point came from, certainly not the article.
EDIT: Are there any studies of deaths within scanners so we can actually see how brain activity reacts to death itself. I'm sure I remember reading something about it taking minutes/hours for the brain to shut down more? That would be a far more pertinent study to look at and perhaps look at how the brain uses up the energy it has left after death.
Interesting then that Robert Shulman said: "You can think of consciousness not as a property of the brain, but of the person."
in his paper cited below, he says that conciousness needs massive amounts of brain energy, yet the amount of energy used to do tasks when reacting to stimuli is minute in comparison.
So when the body dies, what happens to all this energy that supports conciousness?
I have no idea, Dr Shulman has no idea, generations of philosophers have no idea, yet you are so absolutely sure that the energy doesn't change or transform into another state, it simply ceases, which seems to be against the laws of energy conservation, why?
http://www.physorg.com/news164337334.html
High levels of brain energy are required to maintain consciousness
There are two problems with such an approach, said Robert G. Shulman, Sterling Professor Emeritus of molecular biophysics and biochemistry at Yale and lead author of the paper, to be published this week in the online edition of the journal Proceedings of the National Academy of Sciences. First, functional magnetic resonance imaging has shown that many areas of the brain, not just one or two, are recruited during tasks such as memory tests and are scant help in studying the state of being conscious. Second, the amount of energy used in such tasks is minute, about one percent of baseline energy available to the brain.
"Neuroimaging has been looking at the tip of the iceberg," Shulman said. "We looked at the rest of the iceberg."
What is the other 99 percent of energy consumption doing?
Shulman and colleagues have proposed that it is needed to maintain a person in a state of consciousness..... "What we propose is that a conscious person requires a high level of brain energy," Shulman said.
