After finding the missus hadn't checked the oil or coolant of her Fiesta 1.25 LX since september I decided to give the car a check over.
It needed about 3l of oil to bring it up to level (last serviced September). I'm guessing that's not great.
Also, took a look at the underside of the car and found this just under the aux belt (offside front). You can see the OSF tyre and the belt on one of the pulleys (think it could be the aircon compressor at a guess).
Tied the wire up with a cable tie for now to keep it out of harm's way.
What am I looking at?
