Abit Airpace WiFi WLP-01 going faulty?
4 Dec 2008
I suspect it may be. I often get problems with slowdown and eventual disconnection, have done on multiple driver formats so no driver issue.
When it disconnects, it works fine if I go right click->troubleshoot. Here's the additional info:
Code:
Windows Network Diagnostics Publisher details
Issues found
Problem with wireless adapter or access point - Fixed
Reset the wireless adapter - Completed
6 Problems with wireless adapter or access point - Fixed
Reset the wireless adapter Completed
Network Diagnostics Log
File Name:  7CEB8B0C-AF73-4D74-944E-A60C2098BD16.Repair.Admin.2.etl
Detection details
Diagnostics Information (Wireless Connectivity)
Details about wireless connectivity diagnosis:
Information for connection being diagnosed
 Interface GUID: 2d3ca21a-086b-4ec4-85c6-5381366b33ad
 Interface name: Atheros AR5007EG Wireless Network Adapter
 Interface type: Native WiFi
Connection incident diagnosed
 Auto Configuration ID: 2
 Connection ID: 2
Connection status summary
 Connection started at: 2011-05-08 00:47:46-670
 Profile match: Success
 Pre-Association: Success
 Security and Authentication: Success
List of visible access point(s): 1 item(s) total, 1 item(s) displayed
        BSSID		BSS Type PHY	Signal(dB)	Chnl/freq    SSID
00-24-2B-3F-1C-CF	Infra	 <unknown>	-76		3	 BTHomeHub2-XXXX
Connection History
 Information for Auto Configuration ID 2
  List of visible networks: 1 item(s) total, 1 item(s) displayed
  BSS Type PHY	Security	Signal(RSSI)	Compatible	SSID
  Infra	 <unknown>	Yes		32	Yes		BTHomeHub2-XXXX
  List of preferred networks: 1 item(s)
   Profile: BTHomeHub2-XXXX
    SSID: BTHomeHub2-XXXX
    SSID length: 15
    Connection mode: Infra
    Security: Yes
    Set by group policy: No
    Connect even if network is not broadcasting: No
    Connectable: Yes
 Information for Connection ID 2
  SSID length: 15
  Security: Yes
  Pre-Association and Association
   Connectivity settings provided by hardware manufacturer (IHV): No
   Security settings provided by hardware manufacturer (IHV): No
   Profile matches network requirements: Success
   Pre-association status: Success
   Association status: Success
    Last AP:  00-24-2b-3f-1c-cf
   Configured security type: WPA2-PSK
   Configured encryption type: CCMP(AES)
   802.1X protocol: No
   Key exchange initiated: Yes
    Unicast key received: Yes
    Multicast key received: Yes
   Number of security packets received: 0
   Number of security packets sent: 0
   Security attempt status: Success
 Connectivity
   Packet statistics
    Ndis Rx: 35202
    Ndis Tx: 26641
    Unicast decrypt success: 152
    Multicast decrypt success: 0
    Unicast decrypt failure: 0
    Multicast decrypt failure: 0
    Rx success: 178
    Rx failure: 6463
    Tx success: 187
    Tx failure: 0
    Tx retry: 12
    Tx multiple retry: 1
    Tx max lifetime exceeded: 0
    Tx ACK failure: 0
   Roaming history: 3 item(s)
     Times: 2011-05-08 01:43:19-791
    Roamed from BSSID:  00-24-2b-3f-1c-cf
     Reason: 0x00000002
     Times: 2011-05-08 00:50:41-616
     Reason: 0x00000002
     Times: 2011-05-08 00:50:23-611
     Reason: 0x00000002
 Information for Auto Configuration ID 1
  List of visible networks: 2 item(s) total, 2 item(s) displayed
  Infra	 <unknown>	Yes		24	Yes		BTHomeHub2-XXXX
  Infra	 g	Yes		100	Yes		BTHomeHub-XXXX
    SSID length: 15
    Security: Yes
    Connectable: Yes
 Information for Connection ID 1
 Connection started at: 2011-05-08 00:17:17-533
  Auto Configuration ID: 1
  SSID length: 15
  Security: Yes
   802.1X protocol: No
   Security attempt status: Fail 0x00048005
 Connectivity
   Packet statistics
    Ndis Rx: 0
    Ndis Tx: 0
    Unicast decrypt success: 9
    Rx success: 78
    Rx failure: 1258
    Tx success: 54
    Tx failure: 2
    Tx retry: 11
    Tx multiple retry: 7
    Tx ACK failure: 0
     Times: 2011-05-08 00:47:45-183
     Reason: 0x00000007
     Times: 2011-05-08 00:47:39-672
     Reason: 0x00000002
     Times: 2011-05-08 00:45:10-722
     Reason: 0x00000002
 Disconnected from BSSID:  00-00-00-00-00-00   Reason: 0x00000303
Helper Class: Auto Configuration
 Initialize status: Success
Result of diagnosis: There may be problem
File Name:  19AB31CA-9D06-434A-9E98-87A54240B4A9.Diagnose.Admin.0.etl
File Name:  7CEB8B0C-AF73-4D74-944E-A60C2098BD16.Diagnose.Admin.1.etl
Other Networking Configuration and Logs
File Name:  NetworkConfiguration.cab
Collection information
Computer Name:  BASEPLATE-III
Windows Version: 6.1
Lots of dropped Rx packets as you can see. Any ideas? Router is a Homehub 2.0.
Cheers
Inssider is your friend for channel conflicts. Is your home hub is N rated, if you're not using any N rated gear then might be an idea to change it to G only?
check for other stuff using that channel/frequency band. The high number of Rx Fail rate indicates things are possibly getting corrupted in the air.
Homehubs are supposed to auto select less congested channels, but in my experience the just tend to sit on 1 or 11 regardless.
Fire up inSSIDer for 10-15 mins and maybe post the output here?
