RE: My super machine. Pics included.
5 May 2011
I went down to OcUK Friday and managed to collect everything I needed. Here are the pics. I am building it today. I've missed the Dell U2711 from the photoset because the camera didn't save the image properly and couldn't be bothered to re-take. But I have 3 of them.
I am using air cooling at the moment to see how it runs. If temps go too high I will consider water cooling, the only reason I didn't use water is because if anything was to go wrong at some point in the future it could be a waste of money. We have air con. in the room the computer will be in, it's always likea fridge in the room.
Basket total was near £5,500.
http://www.flickr.com/photos/62689232@N08/
Btw. I won't be overclocking the CPU at this stage.
It is clear what most of your parts are..
Regardless of how chilly your room is I believe it was a mistake for you to buy a Venom when you could have gone for a Thermalright SilverArrow.
Anyways, post up the spec and maybe take some group shots.
Sexy pics bro
yep, theres 4. There is even a gap between the 3rd and 4th I assume this is for air flow to stop the soundcard blocking the fans.
If you install 3 double slot graphics cards each one occupies a slot and blocks the one next to it.
You end up with something like this and no slots free:
wWhat version sound card did you get?
As the box only has D2 and not D2X.
That's the PCI version, the board doesn't any PCI slots on it. With the 3-way SLI going on there's only 1xPCI-E slot available, but any card will clash with the chipset heatsink behind the slot.
Edit: Actually looking at the board photo, there might be a slot in the heatsink to allow full length cards over the top of the chipset.
The board I am using is made for 3 way SLI. Look up an image on Google. There is a large gap so that the sound card (or any other device) can be attatched.
I'm not trying to be awkward but:
a) You've bought a PCI soundcard and a motherboard that doesn't have any PCI slots
b) Yes it's made for 3 way SLI and 3 way SLI uses or blocks all the slots on the motherboard
c) You don't even have room for a PCI-E soundcard even if you bought one
Yeah with the 3 cards installed you've only got a single 1x PCI-E slot that's partially blocked by the chipset heatsink.
Edit: In fact that's not even a PCI-E slot :o , I need to get glasses!
Looking at the board in the link below both PCI-E slots will be blocked by the GPU'S as each gpu takes up 2 slots.
http://www.hardwareheaven.com/revie...extreme-p67-motherboard-review-the-board.html
thats the ROG maximus 4 extreme, not the standard, which it looks like he has (either that, or im going blind)
if he has the standard one, he should be able to fit a PCIe sound card in the top slot:
http://images.bit-tech.net/content_...rboard-preview/asus-maximus-4-extreme-2-b.jpg
*edit*
on closer inspection, this board also says RoG on one of the heatsinks, yet there is a PCIe slot on it where the power slot is on that other board.
me = confused
