Crysis/warhead 1080p 24hz issue
25 Mar 2010
Falkirk
Crysis warhead reverts to 1080p 24hz. I have went into launch settings and changed to -dx9(steam)(which resolves crysis wars 1080p 24hz to 60hz) and I have also isolated the exe and added the -dx9 cmd there as well.I have also added a autoexe.cfg to the main crysis warhead folder.
The only thing I can get to work 1980/1076 which I really don't want to do
Now here is the thing I had a pirate copy of the warhead and the above all worked first time so why is the legit version being a pain
Ati crossfire so the alt/enter thing doesn't work and direct refresh program gives me black screen when changed to 60hz
Does anyone have a solution other than the 1076 one,can I remove the 1080p 24 from my ati files so it is forced that way
cheers
Warhead is god awful to set up considering it's meant to be a cutting edge game, I have to go into DX9 mode to change any settings then go back into DX10 mode to play.
I downloaded it from steam yesterday, also downloaded the Extreme quality auto-exec mod for the original crysis and it works fine, and it looks amazing.
I downloaded the file from here. It looked much better after using it.
I am also trying to use Reallifesis, but as that is an auto exec file as well i doubt you can use them both, and i'm not sure Reallifesis works with Warhead anyway, does anyone know?
RealLifesis isn't an autoexec file. It's a .tod file that is installed via the sandbox editor.
