Shift 2 Unleashed - Time Trial Championship Season 1
After doing some testing with stock game and juls mod i find that the stock game is to be blend and not that to drive but in the recent patch the controller input is much better and almost sync to your wheel movement.
Once i installed the juls mod the game become much more fun to drive, there is plenty of grid compared and the feel for the car is much much much better but i would go with whatever the final decision is with stock game or latest patch with juls mod
Also to compare the laptime with stock and juls mod,
Stock game - 51.1
Patch with Juls Mod - 49.9
I'm patched and modded, I reinstalled the patch which hopefully got rid of the mod then I tried it and it just felt rubbish again so I put it back on.
Time so far is 50:708.
Latest Steam version with Juls Mod
Just re-applied the juls minimod and knocked a second off first go, now for some tuning to see if i can compete with the rest of you... ;)
Merlin5 check in your steam folder steam/steamapps/common/needforspeedshift2. look at the properties of the SHIFT2U.exe and check the details tab.
HTH
HTH
Thanks anihc. :) So, is this a patched version? EDIT: nvm, I believe 1.0.1.0 is indeed the patched version.
