Overclocked 550BE to 3.8 questions
17 Aug 2009
Finchley, London
I've put the multiplier on my 3.1Ghz 550BE to x19 @ default FSB 200mhz, making it 3.8Ghz. Cpu voltage at stock is 1.35v in bios, and I've increased by one increment of 0.025v, so it's now 1.376v in cpu-z. I've done some quick tests. 1 hour 20 mins orthos small ffts, and 20 minutes of intel burntest, max stress level, 2 threads. No fails. I'm going to run intel burntest overnight but is this a decent indication of stability or is it too early to tell?
Is it better than intel burntest, because the results of burntest are linpack output.
You sure it's not just for intel processors? I can't install it,
"This binary version of the SMP LINPACK benchmark is optimized for and runs on only genuine Intel processors"
" The primary goal of this benchmark is to measure Gigaflops rating of (Intel) CPU(s)."
