Single loop two res/pump combo's
I seriously doubt that. Water takes the path of least resistance and behaves very like electricity. I see no reason for the water to travel around the first block and suspect that the flow will not be sufficient to cool the first one.
I wait with interest for the actual load temperatures once built.
You're going to be a little disappointed, one of the sensors on my cards is knacked anyways and sticks on select numbers.
I can give you the temperatures of one of them lol.
The best way to tell would be when you first run the pump in the empty system. Which ever water block fills up first gets the best flow.
It won't quite work like that, the first block in the loop will fill first, so care will need to be taken to bleed both blocks properly, but once all the air is out of both blocks it'll work fine, otherwise you might get an air lock in one side.
I would sell them both and get new. Ive had on of those and there not the best. They do a ok job but with the money from selling you can get a mcp655 which will do a great job.
If you run your loop as above you will get one card gettin more water than the other so one card will be hotter
