Expedia Help
4 Jul 2008
Belfast, N.Ireland
Does anyone have any experience with using Expedia and connecting flights. I am planning a trip to Gainesville, Florida for a Music festival. Here is the Flight Details Below:
I am just wondering if anyone knows once I am checked in at Belfast do I need to check in for any of the other flights? Would my baggage just go straight through to Gainesville are would I need to pick it up after every flight?
This was the route which Expedia suggested. So I presume that things like this should be sorted? I have emailed them so I am waiting a response.
Bags only tend to get checked through when you are flying with a code sharing partner.
I think you will need to collect your bags at Gatwick and check in for the US flight.
That's quite a tight connection on the way out, as you may need to transfer terminals, so if you have to collect luggage and check in you will be rushing.
You will also need to clear immigration at Charlote, but not sure if you will need to collect your bags and go through customs as well.
Thanks for the help. Looks like I will have to look into getting a later flight. Because the time between the domestic flight and the US flight on the way out is rather tight and I hate having to rush!
By any chance you know any airlines that code share?
