- 23 Apr 2009
- Cheshire
Ah, that is interesting. So the Furmark test shows that your Graphics card is fine, but OCCT showed that your overclock was unstable.
With that in mind I would suggest putting everything back to stock (the easiest way would be to reset the CMOS on your motherboard) and see if you have any issues at the default settings. The procedure is detailed on page 19 of your motherboard manual (here is a digital copy of the manual).
As for images, the easiest way is to do a bulk upload using imageshack - to do this you need to put all the images in one folder and when you click "browse" on imageshack - select all the pictures you want to upload, this will upload them all at once and give you a link to the gallery which shows all of them. On the image resize option, select "Do not resize". This will be just as fast (if not faster) than attaching them to an email since you need to upload them to do that as well.
Update:
I just showed this thread to a friend and his suggestions were:
- run "sfc /scannow" to check if there are any errors in improtant windows files (have a look here)
- completely remove the overclock, and run OCCT for 6 hours to ensure the system is stable, also check it is stable using Intel Burn Test
- then once the system is known to be stable - backup what you want to keep and fully reinstall windows.
Update:
