Yip sounds like the mobo has had it, I did suspect this to be so.
You just need to decide wether to replace or take this opportunity to do an upgrade.
I'd say the mb has gone to heaven by the sounds of it..
indeed im gonna have a trip down to pc shop(as much as i dislike the place) and see what they got. gonna try get an am3 motherboard, cpu and ram
you need to fix your post mate
For the love of god don't go there.....you will be shafted! And I'm sure forum rules dictate that other retailers can't be mentioned you may want to remove that bit quick
Good luck, any others woes give us a shout
You need to fix your post mate... the purple shirt shop..
Why don't you buy from Ocuk much cheaper..
I did that with the 555BE. If you want to unlock the cores use an aftermarket heatsink. The stock heatsink was only intended for the dual cores, there is a big difference between the 550/555 heatsink and the quadcore 955 heatsinks for example.
*edit* Forgot to say good luck with the build and there is no guarantee u will get the extra cores but you will grin if you get more than you paid for![]()
