Hello everybody,
I'm looking to build myself a new, triple monitor PC, to replace my old and tired machine at work. I've also been itching to try out an Eyefinity setup for a while, so I thought, why not overlap the two! Therefore I’m looking to build a reasonable priced PC with Eyefinity capability (if that’s not an oxymoron?). I've put together the following build within my budget of £350~, excluding monitors/keyboard/mice/OS which I already have.
I've been unable to find a standard size DP adapter on the Overclockers store, are there any compatible DP with the 'Sapphire ATI Radeon HD 5570 (Display Port edition)' I've selected?
As it's been a few years since I last assembled a PC from scratch, and before potentially spending work's money on new PC components that don’t fit together, if anyone had the time to have a quick look at the build and let me know any potential problems or improvements, that’d be very much appreciated
Do you need 8GB? what is the system for?
The SurroundView feature which looks to be just what I need, and thanks for the link to the DP adapter required too.
