Caporegime
- 13 May 2003
- Warwickshire
They're extremely reliable, in that they're not promising anything in the first place.
Crysis
Recommended System Requirements
OS - Windows XP / Vista
Processor - Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory - 2.0 GB RAM
GPU - NVIDIA GeForce 8800 GTS/640 or similar
Thats a no then![]()
My Machine runs Crysis at 1080p on Medium settings around 40fps
Only difference is a bit more ram and a better processor :L Slightly better graphics cardThere is also the windows experience index rating but I think only GFWL games have it on them.
Minimum specs I usually have a cynical attitude about - I pretty much expect the game performance to suck at the minimum spec (even with minumum settings.)Just wondered how reliable the minimum and recommended specs are we see in games before they are released?
Does recommended mean you can crank everything up to the max or near abouts?
My impression was always that minimum specifications means that a game will install and start at least somehow without actually locking up or throwing an error message. The resulting frame rate is not a consideration and could possibly be one frame a fortnight.
It's a shame there's no definition determining a minimum frame rate required to pass the criteria of minimum specs.
