Logitech G9 Shutting Off
29 Apr 2007
London
My Logitech G9 mouse shuts off intermittently. On average every half hour or so. This is getting to be very annoying.
Do you think this is a driver fault or should I send it back?
By shutting off I mean the light on the mouse is going out and windows makes the device disconnect sound.
Thanks, Ross
i had the same problem with my G7, turned out to be the usb thing that goes into the docking station, i also used the software that came with mine.
+1 for emailing logitech, they have an excellent return policy and will probably give you a new one.
Yes, of course.
I contacted Logitech. They said to first try and get it swapped by the retailer and if that fails to contact them and they will replace it.
nice one! was the retailer OcUK? I got mine from Curry's and even lost the receipt! they replaced it with an MX performance mouse
