BMW Ebay Store
Don't see any reason why not to buy from there. How do their prices look compared to buying from the showroom?
Also seems to have good feedback.
Whereas I take the opposite view. The prices of the items I checked are dealer list price - ie exactly the same as you'd pay over the counter at your local dealer, before any discount (Which most will give).
Kinda seems totally pointless really? Can't be bothered with paying RRP on Ebay.
You're right Fox, I thought I had mentioned that - too much alt-tabbing between forums and screens!
Cotswold are a pretty friendly bunch, not really had a bad word to say about them at all. Always quick and cheap. You've more than likely dealt with more dealers than I, Fox, is the usual discount about the 10% mark or do others offer a bit more?
If they offered a complete range of genuine spares and replacement parts then I might be more likely to use it.
Currently, unless you want floor mats, gear knobs or brake pads you're out of luck.
