where have you seen the maximus please?
... going of the gigabyte z68ud5 review the ssd caching thing isnt all that really.
video encoding using the hd3000 is something that i would never really use either
very interested in the gain in fps you will see with all the extra pcie lanes at eyefin res.
well this is why i went for a mobo with the nf200 too, it arrived today..its the maximus. you should see a gain but personally im going to end up getting another 6950(trifire), i want to game smoothly at 5760x1200 with full eyecandy, but i will deffos be trying both my 50's again in the maximus and see what increase i get. the extra pcie lanes are supposed to make a big difference but only @eyefin res, normal one screen res and theres no diff between 8x and 16x, even 4x theres not much in it.
yep i will be watering all mine too, what were your eyefin res's when you had your rampage?
what case have you got, i will have to hack my existing thermaltake armour case to get the third card in. what size rad/s are you going to use and will there be two loops?
cool, the pump doesnt get submerged in water does it? this is the one right http://www.overclockers.co.uk/showproduct.php?prodid=WC-061-XS&groupid=962&catid=1551&subcat=
