- 8 May 2011
very very nice system
holy, how big does that 6950 need to be![]()
nice m8ty.. any benchmarks for us yet?. What are your temps like with the venom?, when i had for my i5 750 my temps where 35'c idel and 65'c at load
Temps are solid.
The next thing to buy is - http://www.overclockers.co.uk/showproduct.php?prodid=CA-227-CM&groupid=701&catid=7&subcat=29
What I'm really impressed with is the lack of "bend" on that card.
Looks good! Very neat. Can I ask why you went with the Caviar Blue though?
Thanks mate, The trick with the gpu is tight wiring and that trick gpu support bracket. I did have to mod it slightly from the picture shown as it came into contact with my side fan. Fits a treat now though.
The only gripe I have about the build is the coolermaster sickle flow side fan is a tad on the noisy side.![]()
Hi Maniac, in what what did you have to modify it? The only reason I ask is because I've just done a build in the same case with a side fan and I'm concerned that when my 6950 arrives I won't be able to fit the bracket in! Oh and if you want a quieter side fan, take a look at the Coolermaster turbine master 120mm fan. I don't think OCUK do them but they are available elsewhere and they really are pretty quiet. I've got one on the side and another in the roof.
Budget and availability really, I will prob end up with a cav black and use the blue as a second drive at some point. works fine though. don't notice any lag when loading from it.![]()
