Hey erm bit of a simple one, I know you can get octane booster but can you get anything to lower it? or is there something you can pour into the tank that will mix with the petrol and lower it? (not sugar, it still needs to be usable) thanks
Well basically my buddy has bought an imported 1988 Chevrolet Camaro, the thing was designed to run on 87PON fuel (91RON) which means putting our 95RON into it is like putting V-Power into a Daewoo Matiz. We figured that by "watering down" the fuel in a way that doesn't ruin it he could save some money with no performance loss.
Yeah I know, buying a 5.0L V8 THEN considering fuel costs, I worry about him too sometimes![]()
. 95ron is FINE to run in that, it'll run smoother, no economy or performance loss and possibly a gain in mpg.Seems pretty pointless imo. Unless putting 95RON is going to cause issues?
people like you should stop thinking. 95ron is FINE to run in that, it'll run smoother, no economy or performance loss and possibly a gain in mpg.
Whatever you use to water it down from 95 RON to 91 RON that doesn't cost money in itself, will increase the volume of fuel by so little there would be virtually zero cost saving.It wont cause issues, but its more the case of the only fuel sold in this country is above what's needed so if its possible to "water down" the mix that would be great, the point is simple saving money by not paying extra for nothing, I would imagine if the was a simple cheap way of downgrading the fuel it might even cover the cost of road tax.
didnt u think about this before importing?
Didn't you think about reading the thread properly before posting?
