New CM Case in stock exclusively at OcUK!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
We have had the first UK stock of the new Enforcer case from CM. This case is in essence a HAF 912 Plus with a different front panel with a door and a perspex window and includes USB3.0 Front Ports. Also included in a 2.5" SSD mount at the base of the case. Quality has not been overlooked here, the materials are all high quality and even the hinges for the front door panel is made of steel as apposed to many other door cases which use inferior plastic hinges.
Coolermaster Storm Enforcer Gaming Case - Black @ £75.98 inc VAT
This new chassis contains a wealth of features coveted by most gaming enthusiasts, including USB 3.0, SSD drive support and a removable/rotatable HDD cage to support easy installation of the highest end video cards.
CM Storm has come up with a design that not only meets the expectations of its customer base, enthusiasts and esports prodigies, but does so within a price range that all will appreciate.
- Front I / O Panel with USB 3.0 (internal)
- Tool - free for 5.25” device
- Dust Filters on bottom and front intakes
- Cable management for better cable routing
- Reinforced front door protects your vital devices
- Supports rear internal 120mm water cooling radiator
- Removable & Rotatable HDD cage for convenient installation
- Support high-end graphics cards including ATI Radeon HD 5970
- Storm Guard - security system for safeguarding your gaming peripherals
- Motherboard: Micro-ATX & ATX
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- 4 x 2.5" Drive Bays
- Front I/O Ports: USB3.0 x 2 / USB2.0 x 2 / Audio x 2
- Front Cooling: 1 x 200mm Red LED fan 1000RPM @ 19dBA
- Rear Cooling: 1 x 120mm Black fan 1200 rPM @ 17dBA
- Top Cooling: 1 x 200mm fan (optional)
- Side Cooling: 1 x 120mm fan (optional)
- Expansion Slots: 7+1
- Max CPU Cooler: 175mm
- Max GPU Size: 390mm
Only £75.98 inc VAT.
ORDER NOW
Here are a few pics from my phone camera.
@danzhang16, this case isn't very good value for money when you compare it to cases like the Fractal Design Define R3 and XL which are only about £10 more. They are far better built and have full soundproofing too.
@Shayper, no this case doesn't really have watercooling support, at least not in the top as there isn't enough headroom above the motherboard tray for a fan and a radiator. The Enforcer doesn't have a seperate section in the roof for the additional fans like the CM 690 II which is much better for watercooling. There should be room for a bottom mounted radiator in this though, although you can have that in the 690 II as well!
EDIT: Just checked and there doesn't seem to be room for a bottom radiator!
See I thought this, but once I saw the case in the flesh I was a shocked, muhc nicer quality and looks better than the photos show. Doubt I would have the case myself though.
I have the case and the quality aint great... they've used far too much plastic which makes it look and feel a bit tacky
The actual innards are pretty much the same as a 912 Plus, the front plastic is sturdy and of good quality. The hinges are made of steel so are of excellent quality.
Maybe the front is rather plastic looking, but the actual quality is Good.
Well he's just gone for the rv02 honestly it would be nice if mates listened to me about wc :rolleyes: cheers anyway :)
Yup it is HAF 912 with exterior modifications mainly. Samething as with HAF 922 and Storm Sniper who although have different exterior but same interior.
It looks okay. it might be something I would get for someone else..
as for watercooling, it looks to be able to take a 240 rad in the top going by the holes
