only cooling that beats me personally is Phase, waterchillers and liquid nitrogenbut they all cost loads more lol
Liquid nitrogen is only really used in extreme overclocking and for short periods of time. It has a use there at least, not an alternative to air or watercooling in my eyes, its for a totally different use.
I haven't used the H60, so I'll bow out at this point, but I will say that all the coolers mentioned are generally very good, and you shouldn't be disappointed with whichever one you choose.
i opted for an h60but mainly due to size constraints in an itx build
I think the only all-in-one watercooler that is supposed to give results anywhere near as good as the d14 is the Antec Khuler 620.
I had a similar choice a few months ago, and I went for the Noctua. It's good, but it's hardly Jesus incarnate like people make out.
I'm now waiting for the Antec H2O 920 to arrive.
The H70 uses pre-applied shin-estu paste, which is good. However, if you screw up the first mount you'll need to replace it.
I used gigabytes equivalent and it shows 52 after 2.5 hours prime .Thanks for the info. I do have AS5 but I did expect I would need to refit it so went with the pre applied paste to save the bother, but it all went fine so I will stay as is for the time being, seems OK.
The tool I used was in fact the Asus own monitor to check temp, seems top agree with the bios readings. In the past I have tried various utils for checking temps and have never got 2 to agree. As it was, I checked the feel of the pump and radiator, and even at full load they both felt OK. I did try the H70 with one fan and one end bolted to the rear of the case to see if the heat sink effect would do away with the need for the extra fan. Seemed fine, but I am now running with both fans with the speed limiter cables fitted, and at 4.4ghz have not gone past 57 running OCCT.
Anyone suggest a good reliable temp guage tool to compare?
