**TODAY ONLY 14/05/2011** Corsair Obsidian 800D Full Tower Case & WD Caviar Green 2TB SATA-II HDD
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Listen up guys, this weekend we have a great couple of Today Only deals.
Corsair Obsidian 800D Full Tower Case - Black @ £209.99 inc VAT
nonl2br<span style="color:blue"><font size="3"><b>Designed for Years of Performance</font></span><br></b>
The Obsidian Series 800D is built to last through years of motherboard, power, memory, cooling, and component upgrades.<br>
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that’s both serious and awe-inspiring. A windowed side panel makes it easy to show off your work. <br><br>
<span style="color:blue"><font size="3"><b>Three Isolated Cooling Zones</font></span><br></b>
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup.<br>
A dust-filtered 140mm fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The SATA hot-swap bays are cooled by a separate 140mm fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment.
Need even more cooling performance? The Obsidian Series 800D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans. <br><br>
<span style="color:blue"><font size="3"><b>Advanced Features for Extreme Flexibility</font></span><br></b>
A four-drive SATA hot-swap drive bay sits in the front of the case, making it easier to install or swap hard drives on the fly. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25” drives. <br><br>
<span style="color:blue"><font size="3"><b>Features</font></span><br>
- Four easily accessed hot-swap drive bays<br>
- Removable CPU backplate panel for easy heatsink installation<br>
- Isolated cooling zones prevent heat buildup<br>
- Unique cable routing holes guarantee a clean and clutter-free installation<br>
- Three fans included, with the ability to add four more 120mm fans<br>
- Tool-free optical drive installation makes building a system faster than ever<br>
- Two year warranty with Corsair’s world-class customer service and technical support<br>
- Dimension: 609mm X 609mm X 229 mm <br>
- 5 x 5.25" Drive Bays<br>
- 4 x 3.5" SATA Hot Swappable Bays<br>
- 2 x 3.5" Internal Bays<br>
- Cooling: 3 x 140mm fans (included)<br>
- Cooling: 4 x 120mm fans (optional)<br>
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio<br>
<br><br>
<center>
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/oX87TPid_po&hl=en&fs=1&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oX87TPid_po&hl=en&fs=1&hd=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object></span>
</center>
Was £224.99 Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Western Digital Caviar Green 2TB SATA-II 64MB Cache - OEM (WD20EARS) @ £58.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 2TB
- Cache: 64MB
- Interface: SATA-II
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £69.98 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Yeah, it'd be good for HTPC storage.
I like the 800D a lot, but it's about £50 out of my budget if I'm being honest. I thought they were quite hard to get hold of nowadays anyway? I have a feeling Corsair were updating it.
If you're not needing the ridiculous space inside I highly recommend the 650d. I own one and they are brilliant. Still has tonnes of space inside as well. Better cooling I believe also.
Indeed, the 650D is my first choice. I like both as they look very similar and have great cable management.
