- 9 Dec 2009
- Bristol
The Prolimatech Super Mega coupled with x2 Akasa Vipers in Push/pull configuration performs admirably, however I was thinking that because both fans face the same direction the max volume of air going through the cooler could not exceed the max throughput of one fan (141 cubic metres per hour).
With this in mind I decided to experiment with both pull/pull & push/push configurations, then compare the results with the current push/pull.
In through one side & out of the other, this is the one which is favoured & I have always used.
Might the above configuration result in more air being passed through the cooler? (141 cubic metres per hour x2?)
Again, I wondered if this would result in more air passing over the cooler.
Conclusion
Pull/pull & push/push does not increase airflow at all, the fans must get slowed down by the restricted route the air has to take in both configurations, so rather than increasing total thoughput of air it's actually decreased. Never had a cooler with more than one fan before & when I got this one I set it up in push/pull following suggestions on here, now I know why.
At least this has put my mind at rest
Conclusion
