Fish & Chips!
15 Feb 2009
Bristol
I'm going to disappoint you all by not having any picture (yet!) :p
Making beer battered haddock tonight with chips and mushy peas.
Done a test run on a few chips, first time doing my own and all I can say is wow! A lot better than expected and better than anything I've had from restaurants/takeaways.
I won't be buying chips from now on that's for sure!
Will update with a picture in a couple of hours. :)
Pictures coming!
But I warn you, it didn't turn out how I expected.
For some very strange reason, the chips didn't turn out how they were earlier (golden/brown crispy and looking lush); they look like normal chips and didn't taste as good.
And the peas didn't look that appetising but tasted great.
Fish was pretty alright.
I'll write the recipe after the pictures :)
Ok just one picture lol.
Took it quickly so didn't realise the DoF, but you can still kinda see the peas haha.
Will have to redo someday and do the chips to how they were first time round :(
I don't like Fish and Chips :eek:
On trips to the chippy I usually go for a battered sausage to replace the fish, and I actually like tinned mushy peas more than the tastless stuff you usually get in chippys.
Recipe!
(Didn't mean to write so much! I seem to keep doing this.. subconsciously procrastinating coursework :eek:)
I didn't measure so it might be vague.
Also I forgot about the peas so I done that near the end but don't know the timing too well for the peas.
Oh and use a metal (not plastic!) slotted spoon to make things easy, otherwise any other metal spoon (of some sort) will be fine.
Preparing the chips!
- I'd recommend using Maris Piper or Desiree potatoes, t'internet also recommends King Edward but I've never used them before.
- I would say about 250-350g per person is about right.
- Peel and cut into cuboids of roughly 1cm thickness, thinner or thicker to your preference.
- Boil some water (enough to cover the chips) whilst leaving them in cold water for 10 minutes or so.
- After the 10 minutes put the chips into the boiling water.
- When the water boils again leave for a minute or two and then take the chips out.
- Rinse in cold water until coolish.
- Heat up the oil (I used 10/90 of groundnut/vegetable oil) hot enough so that if you put in a tiny piece of bread it'll brown and crisp.
- Put enough chips in but so they still have a bit room to move around; try not to stack too much.
- Move them around every so often, but after 2-4 minutes take them out (they shouldn't be browning at this point).
- Put them on kitchen towel or something to soak up most of the oil (can pat them on the top).
- Put them in the fridge for 30-60 minutes, so they've cooled a bit.
- Now you can start to prepare the batter.
Making the batter!
- Pour ~100ml of both sparkling water and any light beer into a bowl.
- Mix in these ingredients:
- 1/2 tsp salt
- Couple of pinches of tumeric and paprika
- A few pinches of cornflour
- A few pinches of self-raising flour
- Now pour and mix in plain flour for however much is needed to make a smooth thick batter
- Stick it in the fridge!
Mushy peas!
I kind of made up this recipe but it did taste nice! It could be better but I won't know until I try next time.
- Defrost the peas
- Melt a big knob of butter into a pan (I probably used 30g or so for two portions).
- Make sure the pan isn't hot and put the peas in
- Squeeze the juice of a quarter of a lemon into the pan.
- Pour a bit (~50ml) of cream/milk (I used milk) into the pan.
- Put the lid on and simmer for 5-10 minutes.
- Leave the heat on but start mashing!
- Once mashed leave it for another 5-10 minutes
- Then turn off the heat and just leave in the pan.
Cooking the fish & chips!
- Near the end of doing the peas, heat up the oil from earlier.
- Pat the fish so there's very little excess water.
- Put a pinch of salt onto the fish.
- Put the fish into self raising flour so they have a thin cover.
- Put the fish into the batter and put into the hot oil (should be enough oil to cover over half the fish, if not all).
- Cook the fish 3-4 minutes each side, then place onto kitchen roll to absorb the oil.
- Season straight after taking them out.
For the chips I'm not sure why they didn't turn out like the first time.
- Take the chips and put it in the hot oil. Don't overcrowd them (which I done second time round so that might have been the reason).
- Turn them every so often until they go a nice goldeny brown colour (about 4 minutes).
- Take them out and place on kitchen towel to soak up the oil.
- Plate up, once the chips aren't still soaked in oil.
- Enjoy!
The problem with the chips was most likely you cooled the oil down to much putting loads of chips in. If I'm making a lot I tend to get the pan almost smoking before adding the chips and then keep it on full heat.
Yep not enough heat in the last cooking stage for the chips.
i'd recommend getting a thermometer of some sorts - you should be aiming for 130C on the first cooking in oil and 180C for the second. Temperature will drop a lot after adding the chips if you've not got a big enough pan.
I'd also recommend cooking the chips longer in the initial cooking - Try and get them so they are almost breaking up on the outside whilst being careful not to turn them into mush. This can take quite a while so be patient, but you will end up with a much crispier end result!
What do you cook the fish and chips in? A large deep saucepan? Half filled with oil?
Nah, I used a non-stick wok. Probably used about 500ml oil.
Thanks, will try that next time :)
Don't bother with a chip pan, treat yourself to a deep fat fryer, least chance of burning down the kitchen.( I have first hand experiene of this:D.)
I have a Delonghi F26237 Deep Fryer,cost £41 , does superb chips, batter sauages aren't bad, just need a bit more pratice with them, fish is also great.
Pea fritters are next on the list to try.
