Man of Honour
- 21 Nov 2004
Run some Heaven too - do these for many hours. If you notice any problems, RMA it if you can.
If it can survive furmark, it is fine. Sure your MB chipset drivers are up-to-date?
Corsair and XFX probably both manufactured by Seasonic.![]()
I know that both corsair and thermaltake psu are both the same units made by Channel Well Technology
And a quality psu is a must
good point. checked them they werent updated.
if you are buying a new psu then i recommend you get a corsair.
All this nonsense about cheap PSU's...
I have the same one (all be it 650w) and have an OC'd CPU and GPU never a problem. It's probably producing less than that, but the fact is it could be producing 300W and it'd still be plenty.
Never has been a problem have always mixed cheap PSU's with expensive components all the paranoia comes from AMD/ATI/Nvidia as a sort of disclaimer.
Have you considered it may not be your GPU?
I'd put money on it being your CPU.
Download "OOCT" give it a whirl.
Assasins Creed killed off my xbox even with the x clamp mod, and that was CPU related.
If your whole PC crashes it is most likely your CPU, usually GPU crashes should bring up a driver error and revert you back to the desktop.
the new psu came, although the graphic crashs are still happening.
will flashing the bios fix it?
what are the chance of it being a hardware problem?
Indeed.And a quality psu is a must
new psu working fine every thing else cpu, ram all tested. 100% fitted properly. benchmark in furmark 2 hours no problems sometimes sometimes it crashes after 5 minutes. got it from the bay.
