teulk, try the the following things.
1. Turn overscan on and off and see if it makes any changes to the image regarding the flicker.
2. are you sure it's not your source doing this flicker have you tried other equipment on the tv and noticed the same thing ? Also is the source set to the correct setting 1080i or 1080p or 720i or 720p and on a PAL signal not NTSC.. ?
3. do a factory reset on the tv and check for any updated firmware for that TV.
4. Have you turned on some image processing on the TV that could be causing this ? (this is why I say do a factory reset and see if it did what it it did when you 1st baught it)
5. could be bad cables connecting the source to the TV ?
6. have you moved anything recently that could interfere with the TV , eg wireless router near by or mobile phone or land line cordless phone ? or any electrical device too close to the tv that can cause interference ?
7. Do you have the TV on a surge protector ? Some surge protectors can sometimes make devices behave funny, remove it as a test too if you have one and see if it cures the problem. Also try a different power source in the house with an extension cable (saves you moving the tv).
If all fails look up the model number of the TV and see if anyone on the internet is having the same problems as you... By the way which model number is it you have ?
