Does anyone know where I can find one? Looked on auction site but only found a used one. I know the whole competitor links thing may make this difficult, if they're available, but I don't really know where to look. Any ideas?
Post a wanted ad in the Members Market. Someone will have one.
andi's listed 2 great value coolers but if you want to spend the bare minimum the Cooler Master Hyper 212 also uses a bolt through kit and has excellent cooling capabilities for under £20.
I think I've failed to explain the situation with the current motherboard clearly enough. The holes in the mobo are blocked by posts which pertrude through the board and are attached to the plate which is glued to the back of the board. I don't think this can br removed.
