Logitech Keyboard Deals
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
I have a nice few deals on keyboards to suit every budget.
Starting with the 600 Media Keyboard
Logitech 600 Media Keyboard (920-000031) @ £11.99 inc VAT
Get the comfort, quality and simplicity you expect. The Logitech Media Keyboard 600 features a truly inspired design that makes accomplishing your tasks easier and more enjoyable. Convenient launch controls and hot keys are cleanly blended into the streamlined and glossy styling. The soft-touch keys deliver an extremely comfortable and quiet typing experience. With the Media Keyboard 600, adding comfort and control to your computer is easier than ever. Mainstream USB connector lets you connect quickly and easily to any PC or notebook. It is ready for Windows Vista and Windows XP and comes with a 3-year guarantee.
- Streamlined, elegant keyboard with convenient launch controls
- Comfortable, responsive soft-touch keys
- Easy one-touch access to your favourite applications
- Superior reliability, spill-resistant design
- Elegant polished styling
- Intuitive volume dial
- USB connection; Windows Vista or Windows XP
- 3-year guarantee
Only £11.99 inc VAT.
ORDER NOW
Next up is the Logitech Illuminated keyboard
Logitech Illuminated Keyboard (920-001165) @ £54.98 inc VAT
Illuminate your typing experience – night or day – with the Logitech® Illuminated Keyboard. Bright, laser-etched, backlit keys let you type easily, even in the dark. The ultra-thin, 9.3 mm profile provides a cutting-edge design that adds an elegant touch to any desk. The PerfectStroke™ key system, with its precision micro-scissors, helps make every stroke comfortable, fluid and silent by giving you more key travel than typical notebooks keyboards. With its sleek, minimalist design, the Logitech Illuminated Keyboard delivers the ideal combination of form and function. And the soft-touch palm rest and full-size key layout help you type comfortably – even after extended use.
- Bright, laser-etched, backlit keys let you type easily – even in the dark.
- Ultra-thin, 9.3 mm profile provides a cutting-edge design that adds an elegant touch to any desk.
- PerfectStroke™ key system helps make every stroke comfortable, fluid and silent.
- Sleek, minimalist design delivers the ideal combination of form and function.
- Soft-touch palm rest and full-size key layout help you type comfortably – even after extended use.
Only £54.98 inc VAT.
ORDER NOW
And finally the MK520 Wireless keyboard and Mouse
Logitech Wireless MK520 Desktop (920-002606) @ £35.99 inc VAT
The Logitech® Wireless Combo MK520 puts convenience and control comfortably at your fingertips – whether you use a laptop or desktop. The sleek, full-size keyboard gives you the room you need to type comfortably, while the concave Logitech Incurve keys™ cradle your fingertips. The full-size mouse offers smooth, precise laser tracking and feels good in either hand – hour after hour – thanks to its hand-friendly, contoured design with soft rubber side grips. And your desktop is hassle-free with up to three years of battery life for the keyboard and one year for the mouse*, a tiny Logitech Unifying receiver that you can plug and forget, and Logitech Advanced 2.4 GHz wireless connectivity. * Battery life may vary based on user and computing conditions.
- The keyboard’s full-size layout gives you the room you need to type comfortably – with all the keys where you expect them to be. The concave design and softly rounded edges of the whisper-quiet, low-profile Logitech® Incurve keys™ position your fingers properly and invite your fingertips to glide from key to key, hour after hour. The palm rest gives your hands the perfect place to rest when you’re not typing. And you can store your keyboard standing up to free up space on your desk when you’re not using it.
- The full-size mouse feels good in either hand – even after long hours of use – thanks to its hand-friendly, contoured design with soft rubber side grips. And laser precision means you'll enjoy smoother tracking on just about any surface so you can say goodbye to the frustrations of basic mice and tricky touchpads.
- Up to three-year keyboard and one-year mouse battery life. Better power management practically eliminates the need to replace batteries.
- The tiny Logitech® Unifying receiver is small enough to stay in your laptop and connects both the included mouse and keyboard, so they're ready to use whenever you need them. Plus, you can easily add another compatible mouse, keyboard or number pad – without the hassle of multiple USB receivers.
- Logitech® Advanced 2.4 GHz wireless connectivity gives you the reliability of a cord plus wireless convenience and freedom – fast data transmission, virtually no delays or dropouts, and 128-bit AES encryption.
Only £35.99 inc VAT.
ORDER NOW
whats so good about it? £50+ for a keyboard which isnt a gaming one, i dont see the sense in it.
It is very comforable to use, has a minimalistic design to it and looks good, has backlit keys, the tactile feedback is strong, the quality of the keyboard is also strong and sturdy too. These have been extremely popular keyboards for a lot of home and business users who wants something that looks mainly nice and swish but has all the other good features to it too.
I use the Logitech Illuminated Keyboard for gaming = P
Can't see myself buying any other keyboard, I picked up in the MM brand new for £35.
I've used the MK520 combo which I found the be very good, the keyboard is comfortable and the mouse works well. No problems with the wireless. Only used for everyday tasks like internet browsing, not really suitable for gaming.
It's a great price for keyboard and mouse.
I'll second that. Have used Illuminated keyboard for a couple of years now and it is definitely the best one ever produced by Logitech.
Awesome I just saved £27 by waiting a week!
Just ordered the Logitech Illuminated Keyboard and Logitech G700 Wireless Gaming Mouse.
