£1000 gaming pc with monitor
Well don't I feel like an idiot now - I don't even know what 'noise on the voltages' means...:o
Off to google I go :D
noise on the voltage is fluctuations from the intended voltage. with a lot of noise it would look like a seismograph (sp?) during an earthquake, but with very little noise it would be relatively smooth
as far as i know, as long as its within 5% of the intended value, and its reasonably smooth, everything is fine
Ok so my budget has been increased to 1200 (lovely grandparents :)) , I've got already got a heatsink so that takes a little off and I've got an 800w psu in my current pc so was thinking I shouldn't need to upgrade that, posting on phone so can't tell make of psu again any spec greatly appreciated!
without know the make/model of your 800W PSU we cant determine if its any good.
Keep what you had,
Either,
Get a really great screen.
Bigger badder case
Heres a better build:)
So we have some of the same bits you selected.
But fitted a bigger case
Better monitor.
Included Win7 and Blu-ray drive like you wanted:)
Ok the psu is an atrix 800t and heatsink is freezer pro rev 2 if that helps cheers guys
You are going to need a higher quality PSU, cheap ones never put out the wattage stated on the labels, and thats a awful lot of money to trust to such an item.
If the freezer pro rev 2 has a intel socket 1156 mount? then it can be used, but either way the Retail CPU comes with a heatsink anyway.
That's nice to know about the oc, really nice build there stulid also liking the case and ssd olivier, think I'm going to mix and match your two specs thank you!
Just post up whatever you thinking off. so I can give it the once over.
Ok final build hopefully all is good
Dell Ultrasharp U2311H 23" Widescreen LCD Monitor - Midnight Grey 1 £191.66 (£229.99) £191.66 (£229.99)
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card 1 £166.66 (£199.99) £166.66 (£199.99)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor 1 £129.99 (£155.99) £129.99 (£155.99)
MSI P67A-GD53 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** 1 £91.66 (£109.99) £91.66 (£109.99)
Coolermaster HAF 932 Advanced Full Tower Case with USB3.0 - Black 1 £89.16 (£106.99) £89.16 (£106.99)
Corsair TX 750W ATX SLI Compliant Power Supply (CMPSU-750TXUK) 1 £66.65 (£79.98) £66.65 (£79.98)
OCZ Vertex 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX60G) 1 £61.66 (£73.99) £61.66 (£73.99)
Microsoft Windows 7 Bundle - Home Premium 64 Bit 1 £57.00 (£68.40) £57.00 (£68.40)
Options applied to the above product: Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) 1 £27.49 (£32.99) £27.49 (£32.99)
Samsung SH-B123L/BSBP 12x BluRay ROM / 16x DVD±RW Lightscribe SATA-II Optical Drive - Black (OEM) 1 £39.99 (£47.99) £39.99 (£47.99)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) 1 £29.99 (£35.99) £29.99 (£35.99)
Sub Total : £951.91
Shipping cost assumes delivery to UK Mainland with: DPD Next Day Parcel (This can be changed during checkout) Shipping : £22.20
VAT is being charged at 20.00% VAT : £194.82
Total : £1,168.93
