I'm confused..B3
23 Mar 2009
Pre-B3 revision motherboard users can also download and use the new B3 revision BIOS, drivers and utilities. Go to the ASUS support site at http://support.asus.com to download the latest BIOS version.
That means issues are resolved???
edit: I will have 9 HDD internaly!
The issue is only resolved by having a motherboard with a B3 revision chip.
No BIOS update can fix a B2 motherboard.
The BIOS for B2 & B3 revisions is the same because there's no functional difference between the motherboards.
Pickup up 3 F1 640gb for £50.00 Asus gen2 satag6 £15.00 (not installed yet!)
Got an corsair TX V2 850w
Fractal Design Define XL Full Tower Case - Titanium Grey
H70 @33c Prime 95 @60c
room temp 22.5
Hell yea!
The flaw with the B2(?) chipsets is of a physical nature due to a manufacturing oversight, they're probably the same chips on a hardware level which is why the BIOS's are interchangeable.
