- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
The Corsair H50 Watercooler can be purchased for an amazing £39.98 inc. VAT using the voucher code "h50promo" when at the checkout on our site. This offer ends on Thursday the 19th May at 9am or when stock runs out.
Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) @ £50.99 inc VAT
nonl2brThe Corsair Hydro Series™ H50 CPU Cooler gives you the power of liquid cooling in a compact, easy to install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
The Hydro Series H50 goes head-to-head with top of the line heatsinks, but maintains the near silence of liquid cooling for annoyance-free cooling performance. Due to its compact form factor, the H50 is the ideal solution for any case with a 120mm fan mount, even small form factor cases that prevent the installation of traditional heatpipe based air coolers. So whether you want world-class cooling, lower noise levels than your current CPU cooler, or something that fits in your small form factor case, the closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large 120mm radiator for fast heat dispersion
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator<
- Two-year warranty
Was £50.99 Inc. VAT
Only £39.98 inc VAT. If you use the voucher code "h50promo" on the checkout screen
ORDER NOW
- Two-year warranty
Was £50.99 Inc. VAT
ORDER NOW
