So I fancy myself a bit of an amateur gardener and I'm having a lot of success growing a range of plants. one thing however that isn't going so well, is my yellow courgette plant.
When I first got the plant about a month ago, it was a relatively new seedling with 2 primary leaves. The stalk kinda curves out, it's not a straight plant and I don't know if this is an issue. I planted it in one of my wooden pots (about 20cm diameter, square pot) with some general purpose and organic compost and fed it weekly with liquid feed. I watered it either daily or every two days, depending on how dry the compost got.
For a while, the plant was doing well. It's in a position where it gets full sun for a good portion of the day and all my other veggies appreciate the same positioning as I have a south facing garden. It's grown a good number of it's proper leaves.
I have noticed a few things. Since day 1, it has never been a vibrant green colour; although I assumed this was just the nature of the plant. I did notice an initial problem where the edges of the leaves were dying, slowly moving inwards (as in going brown and drying out). This didn't seem to be an issue as the rate and size of new leaves was good, however I've now noticed most of the leaves die shortly after sprouting. I've now moved the plant to a much larger pot, with richer veg compost and I've been running a course of tomato feed every couple of days to see if it in improves together with it's regular watering. So far it's not getting better and the leaves are slowly dying. it's also not really growing much at all.
Can anyone weigh in on an opinion of why this might be happening?
