Very Interesting Concept.
I like the thing, but for disaster relief, how is this better than just a tent?
a tent must be lighter -cheaper- more transportable, only slightly less sturdy, but disaster relief shouldn't be long term.
In serious situations where disaster relief is unfortunately long term, this would provide a durable, seemingly sterile refuge/triage/first-aid location. Normal tents would have course be more viable initially, but these concrete tents would be much more viable for the long term.
Indeed.
Clever chaps, wish them all the best with it too.
Greater protection from the elements, more permanent, ability to add services and drill holes, etc etc.
Being able to control the heat better than canvas would be a good point, in extreme conditions or not so extreme.
You could probably drill out a bit in the roof for a chimney if needed.
To be fair, I did just steal your post and expound upon what you said. :p
Which I couldn't be arsed doing, so thank you :) :p
Yeah but by the look of it you leave the inflatable up inside anyhow?
Am not saying its a bad Idea, was just wondering how much strength this stuff really adds thats all.
It would seem so, gives it a nice look inside. I guess you can remove it if you wanted to however, or at least tear at sections off the ceiling.
The wall didn't seem to still be covered with the canvas, where the plug sockets were for example...
It's concrete, so probably quite a lot over fabric tbh.
why not just use the inflatable and sod the concrete off though?
Because then you will need continual 24/7 electricity to fuel the pump.
I think it's a great idea.
For the person who mentioned earlier that it wasn't portable to remote locations, airlift by helicopter.
Good idea, in the short term this would not easily be deliverable. As many have said it is better effective a couple of days after for longer term relief. In the example of earthquakes, I suspect you don't want a semi-permanent concrete structure having to withstand repeated aftershocks. Other events though would be perfect and being able to construct emergency hospitals which are clean and secure would be invaluable!
