Is that an i3 nahalem (three digits in the model number) or i3 sandy bridge (four digits in the model number? Also, is the phemom X4 a Phenom 1 X4 or Phenom II X4?
As for GTX 460, is that the GTX 460 768MB or 1GB versions as the 1GB has more ROPs and a wider memory bus - as well as more video RAM.
As for the GTX 550 TI, if you look at this review it isn't as good as even the 768MB version of the GTX 460.
So a Phenom II X4 840 and a GTX 460 1GB in the first system?
That's better configuration for gaming than an i3 530 + GTX 550 Ti.
Instead of buying a pre-build, have you considered building the system yourself?
An i3 2100 sandy bridge would be a good choice on a low budget (it costs about the same as an i3 540 new and is newer tech and a good deal faster in games).
May I ask what your total budget for your system is, what you will be mainly using the system for and do you need anything apart from the tower (monitor, mouse, speakers etc.)? With this info i'd be happy to put together a list of components that will all work together and you can assemble yourself.
Here is a well written guide to building a PC if you are interested.
Looks good, that board will picked can't do dual cards, but this one which is £10 more can -at proper x8/x8, plus it supports both SLI and crossfire (just make sure you get a PSU that will power both cards), it also support CPU overclocking. All-in-all a very nice board.
As for the CPU, I would strongly suggest going for this CPU, as it can overclock to the sky (aim for 4.5GHz) and is £5 less than the non-K 2500. The only problem is it doesn't come with a stock cooler - but if you go for this cooler then you will be able to keep it cool and quiet and overclock it pretty far.
Also, in terms of graphics card, the HD 5850 is now at £120 (same price as the GTX 460 1GB). This is how the two cards compare:
http://www.anandtech.com/bench/Product/313?vs=295
hmm the cpu looks awesome tbh but i really want an nvidia card because eveonline is working close with nvidia with physx and i want to be in on the ground floor with that one, also i think they put something in their game recently that favours nvidia over ati seeing as loads of people using ati cards are having new problems duel boxing clients
lol considering i started with a 500 budget im gonna be broke for the next few months to buy all this kit![]()
That makes sense - GTX 460 1GB it is then.
Lol, I know what you mean. However, you can justify it by saying "well i'm investing in slightly more expensive, but much faster kit - so I'll be saving money in the long-term as I won't need to upgrade for longer" - that's the way I justify my kit to myself anyway![]()
