What's the point in turning of your pc and leaving the router still plugged in?
I'm hopping android will bring the costs down. It needs mass production behind it. It just seems totally skipped over by the public, who see it as a gimmick rather than something useful.
Would love a button I can press that turns everything off, including heating when I go to work.
Or heating that is based on my work Callander(shift work). Or a dimmer light that slowly comes on over half an hour before my alarm goes off. Got a grow box in my room and lights come on at 6 makes such a difference. So for me it's not just energy saving.
This is why I threw CAT6 all around the house, including the utility room.
I was hoping to eventually wire in the boiler so I could set up custom on-off timings or link it to a control and do it over the internet. Remote heating etc
Some of the scripting on homeautomation.co.uk, with alarm systems and lighting is crazy. Having the drive lights come on if a sensor triggers, picking up movement towards the house, after 7pm and the alarm is deactivated etc. Having the doorbell to divert the loudspeaker to your mobile if there's no one in the house (linked through the room PIRs). Mad![]()
This + I tend physically pull the plugs from appliances if we're away too.
There's no point really is there? If you leave it on at the wall it just fills an empty circuit which never reaches the device and probably doesn't consume a noticeable power draw. I do love the uproar about leaving things on standby, as in reality you're wasting the draw to keep an LED running..
