- 24 Apr 2011
Ok so I'll start by posting my System Specs.
CPU: Pentium (R) Dual-Core CPU E5200 @2.5GHz
(Current clock speed: 1200Mhz
Max clock speed: 2500Mhz
1.2V)
GPU: HIS Radeon HD 4850 HD 1GB
RAM: Corsair 2x2GB
Motherboard: Asus P5KPL-AM
PSU: Not sure about the make and stuff, think its like 500W though. Will check.
Colling Device: Just 2 regular fans
Well, I want to overclock my CPU and GPU. Is it worth OCing them, or will the power given by these not be worth the effort? Also, will the heat coming out of them be tooo high, and thus damage my system? I also have another small problem, that I only have 3-4 cm from the edge of my case to the nearest wall, is that too little??
If you give me the green light, I need DETAILED instructions to do this. Do you know any good free programs to calculate temperature etc.
Thanks
P.S. Yes, I know there are MANY threads about this, but it seems to me that every person has his own problems etc.
1.2V)
RAM: Corsair 2x2GB
Thanks
