- 31 Jan 2011
- Hampshire
Getting a 2500k and a gd65 board will the venom do the trick ? Size cooling effect etc or any other suggestions i will be overclocking as much as i can
Just make sure you get a low-profile DDR3 kit like this and you won't have any issues with heatsink clearance.
Personally I would be going with the Thermalright Silver Arrow if I were buying a new cooler (but I am a bit mad) - it cools extremely well and the large, low speed fans mean it's extremely quiet. If you don't want to spend that much then the Venom is a good choice (personally I would go with the nero S as it is quieter).
With the H50 if you enter h50promo on the voucher section at check out you get it for £40.
EDIT: http://forums.overclockers.co.uk/forumdisplay.php?f=7
See the banner on the top right?
That was the ram i was going to go forover 50quid on a air cooler is a bit extreme unless the results are epic
Plus free postagedo u think this will be better than the venom in tern of cooling ?
