Motherboard trays
9 Apr 2007
Im planning on building my pc inside a drawer under my tv, to make things easier for mounting i was planning on using a motherboard tray but im not having much luck finding something suitable.
Something that just holds the motherboard and the pci cards.
The Lian Li PC60 ATX Motherboard Tray is as close as i have found but would need some chopping down.
Anything similar out there?
I used that motherboard tray in my ongoing (and possibly never ending) G5 project, chopping up wasn't a big issue. Lian Li also sell a tray with nothing but the tray itself and the pci slots called the Q6ATX. Maybe that's closer to what you need?
I did see that but i think something with the backplate as well makes things easier and neater.
I cant find anywhere in the UK that has the PC60 tray in stock.
yeah it was the first thing to pop into my head :p i'm sure someone will have a removable motherboard tray on the MM
I will definitly keep an eye out in there.
I wonder if this come apart enough to just use the tray and card holding bit.
Dimastech® Bench Table Hard V2.5
Another id reccomend is the slide out mobo tray from an akasa eclipse 62. This tray also features the pci card slots.
