Its the same for all types, its basic feature of their design.
Even for PSU of different wattage? both a 1000W and 650W PSU performs best at 50/60%?
Yes.
So 600w for the 1000W PSU
390W for the 650W PSU
± a bit either side
Heh, my Steam folder was bigger than that 'til I saw the light recently and deleted all the dross ^_^...I've never filled the 200GB HDD on my old PC, so I'll never fill the 1TB I'm picking up, so just 1 HDD.
Yes, its best to run a high frequency switching mode PSU at around 50-60% for best efficiency.
take this bell curve for the TX750
Just buy any suggested to you and stop over analyzing the problem, you want the option later.
You also dont want to run a PSU maxed out.
+1 max efficiency is at 50-60% by the shape of the graphs in those reviews!
EDIT: i have just had a look at my energy bill and it says that it is 10.8p/KWh, i wonder how much a 1000w PSU would cost in a year![]()
1000W.
For SLI, 1200W with potential for heavy overclock.
Any idea what you're spending a year right now? I might be able to make an estimation on a 1000w then.
Any ideas on how much percentage-wise I'll be using up with the above setup using a single GPU on a 1200w?
I'm just trying to determine whether or not the PSU will be running too inefficiently for that year or so with the single GPU to even warrant going for a 1200w or not.
GTI480 Furmark : 650W
GTX480 SLI Furmark : 850W.
At Idle, a lot less.
If you're worried about efficiency at low load, get a Gold rated PSU.
sorry, cant give you that information, only had this rig for 6 weeks![]()
