Tubes is that the Vika Amon long table top? Also whats that unit on the desk top holding your monitors?
Thanks tubes pics on thier site dont do it justice, whats that unti you have on the top though m8?
It's a homemade unit as such. Basically it is another vika amon desk cut in half length ways with the supports made from from the remaining half. Pretty easy to do, it took about 90 mins and gives you so much more desk space.
My desk, with the 3 legged cat called Pumpkin.![]()
Nate Silvers,
Where di you get that tv/monitor stand from?
Nate, you're mouse is on the wrong side... You're doing it wrong!!
Nice desk, looks like a posh version of the ikea mikael(but better)
I like the monitor arm too, makes the desk look massive without the monitor sat on it doesn't it!
Just moved into my new flat and built my new table *explodes* absolutely shattered but happy I have a desk to sit at once again~
my 2 new builds
Airsoft btw
specs
phenom 2 x6 1090t
16gb consair dominator ram
Galaxy gtx460 razor
asus m4n75td mobo
xfx pro 850w
all inside a silverstone rv01
^_^
specs
phenom 2 x6 1090t
Galaxy gtx460 razor
asus m4n75td mobo
xfx pro 850w
^_^
its good never goes over 75c, it gets loud under load though,no sli eitherLove the rv01 it's probably my favourite case I've ever seen
How is the gtx 460 razor?
can never have enough ramOh nice 16 gig of ram, you went all out! lol
no sli! that isn't goodits good never goes over 75c, it gets loud under load though,no sli either![]()
