Your CPU is perfectly fine for Crysis, @3.6ghz it will not be bottlenecking your performance.
My good nemesis it matter about relevance. If the guy is getting helped out then that is all that matters.
And your problem is you are over defensive regarding the performance of Phenom II CPU.It matters when the help has already been said & everything else will not change anything in regards to that game with the setup he has & well give him the impression that more CPU will let his run at a higher setting which it will not in that game.
The problem is that Marine-RX179 goes on about the CPU all the time regardless of the OPs issues.
Dual Thread on Hex core CPU...I ran Crysis about an hour ago & its used very little CPU.
Marine-RX179;19186468 1) said:And your problem is you are over defensive regarding the performance of Phenom II CPU.
Last time regarding the CF6990+6970, I say overclocked Phenom II X6 is not making the most out of that graphic set up and has room for improvement on frame rate if the OP got money to upgrade to Bulldozer or SandyBridge in the future, and you keep going on and on about how Phenom II X6 is not lacking in performance.
This time, I merely pointed out that Crysis is a dual thread game, meaning that the game itself won't really use more than two cores, so the CPU that run dual thread quicker will deliver higher frame rate. and i5/i7/SB are faster in dual thread than Phenom II X6. I did not say the overclocked Phenom II X6 at 3.6GHz would be a huge bottleneck for CF6870, so I have no idea why act like a hedgehog always always having the needles up to defend the precious Phenom II, when everytime I merely mention that overclock i5/i7/SB deliver higher frame rate than overclocked Phenom II (which is a fact).
2) Dual Thread on Hex core CPU...
http://www.legionhardware.com/artic...ossfire_cpu_scaling_performance_part_2,4.htmlWhich does not matter if it maxed out the CPU or not as im GPU limited in that game regardless with the settings i like to play at.
And in fact the fact that a i5/i7/SB should be a faster setup over all for most tasks why don't everyone use them? because lesser systems are fast enough already, hence your Sig.
Crysis Warhead CF5870 1680x1050 0xAA 0xAF
i7 9xx 4.0GHz: min 44fps, average 60fps
i5 7xx 4.0GHz: min 43fps, average 60fps
Phenom II X4 4.0GHz: min 34fps, average 55fps
Phenom II X2 4.0GHz: min 30fps, average 54fps
1)When AA and AF are applied, I wonder which will struggle to keep the minimum frame rate above 30fps....
And for your claim of GPU limited circumstances CPU don't really matter, let's take a look at 2560x1600 (again at 0xAA, 0xAF):
http://www.legionhardware.com/artic...ossfire_cpu_scaling_performance_part_2,5.html
i7 9xx 4.0GHz: min 23fps, average 34fps
i5 7xx 4.0GHz: min 23fps, average 35fps
Phenom II X4 4.0GHz: min 18fps, average 36fps
Phenom II X2 4.0GHz: min 18fps, average 35fps
Let's have a look at another game with CF5870- World in Conflict 1680x1050 and 2560x1600 0xAA, 0xAF:
1680x1050
i7 9xx 4.0GHz: min 30fps, average 104fps
i5 7xx 4.0GHz: min 31fps, average 102fps
Phenom II X4 4.0GHz: min 18fps, average 72fps
2560x1600
http://www.legionhardware.com/artic...ssfire_cpu_scaling_performance_part_2,13.html
i7 9xx 4.0GHz: min 34fps, average 91fps
i5 7xx 4.0GHz: min 33fps, average 90fps
Phenom II X4 4.0GHz: min 18fps, average 69fps
The CPU bottleneck there is quite clear in showing that Phenom II doesn't keep up in the slightly more CPU demanding games that are not optimised for more than Dual Thread, rather it is at or is not at GPU limited situation. But for games that are well-optimised for using multi-cores (i.e. BFBC2), the Phenom II would likely to keep up with overclocked i5/i7 etc. But sadly well-optimised games like BFBC2 don't come most of the time, as we tends to get half-arse console port majority of the time that struggle to even use 3 cores well.
IF the GPUs still has enough spare usage that is. However, my point is still valid for Phenom II will struggle in CPU demanding games that are run in Dual Thread or less (the World in Conflict results is already quite conclusive).Fail because AA and AF is GPU bound so if it was still CPU limited with more AA and AF then the frame rate would stay the same.
And my rigs plays it faster than all of them 2560x1600 (again at 0xAA, 0xAF)
And you always come back to Crysis as if that's the only game that exists & again this thread was about stutter & not about low frame rates & like the other thread the OP was not complaining about low frame rates or even crysis but again you bring out the crysis benches as if all games behave like it.
1)It's been widely acknowledge that shattering for Crossfire set up tends to be most noticable and most likely to happen when frame rate is at below 30fps, and it includes Crysis, but not limited to it. There are other examples such as in Metro2033 as well as in Heaven Bench.
2)IF the GPUs still has enough spare usage that is. However, my point is still valid for Phenom II will struggle in CPU demanding games that are run in Dual Thread or less (the World in Conflict results is already quite conclusive).
3)The point of the 2560x1600 result is to show that even at GPU limited situation, Phenom II would still falls behind.
4)Did I use ONLY Crysis as presenation for Dual Thread game here? I don't see why you fail to realise that there are quite a lot of games were already fairly CPU demanding back then, which Single to Dual Thread was not exactly providing enough for them. Crysis is just one of them, and then there are others like World in Conflict, X3 Terran Conflict, WOW etc.
Crysis is a buggy, inefficient, and boring/horrible game. Move on to better things.
1) Yes we know & but at his res & AA settings both CPUs will fail to hold above 30fps at times with his GPU so one beinf a bit faster makes no odds as they both still fail, fail is fail. less fail is still fail.
I don't care & most dont care if 100% faster Intel get 10fps FAIL but AMD get 5fps..FAIL.
2) Again & like said the averages are the most important & are way above of what is needed & again if the GPU has no spare usage then it would not have a higher average on a faster CPU.
3) GPU limitation means it does not scale more with CPU, if it scales on average then its not GPU limitation.
4) Again still fast enough averages & the majority of people who play those games are on far weaker GPUs & CPUs than the AMDs.
But still have nothing with the OPs stuttering at 8XAA because you showed nothing with 8XAA because then you will see the lead that Intel has which is quite small in some games with AA/AF gets even smaller or nothing at all & this thread is not about which is faster.
1) If you actually go back at look, the i5/i7 at 4.0GHz with the CF5870 at 2560 has minimum 23fps, what it means is that if overclocked them a bit higher to 4.2-4.4GHz, it should reach minimum 25fps, so it would manage to become playable (just barely) without AA (if shuttering does not occur that is); the Phenom II on the otherhand is at 4.0GHz and got no more overclock headroom left, with the minimum frame rate at 18fps so it's unplayable.
2) Having spare GPU usage and having enough spare GPU usage for applying AA without impacting on frame rate are two different things
3) Even if average frame rate were the same, the faster architecture CPU would offer higher minimum frame rate (even a faster motherboard would be able to deliver higher minimum frame rate on the same CPU and graphic card(s).
4) I wonder how people gotten i5/i7/SB just for the sake of getting smoother frame rate in WOW or the Total Wars games, because of the game's limitation with them basically being a Single~Dual Thread game?
Now that the Core i7 scaling results with the Radeon HD 5970 are in, it is time to see how the Phenom II X4 processors handle this monstrous graphics card. Again we will be testing at frequencies between 2GHz and 4GHz in a range of games, while comparing the results to those recorded with the Core i7…
http://www.legionhardware.com/articles_pages/cpu_scaling_with_the_radeon_hd_5970,13.htmlThe Phenom II X4 results were quite different to those recorded when testing with the Core i7 processors, though this was not necessarily a bad thing. When operating at lower clock speeds, the Phenom II X4 did not fair all that well, as we saw a sharp decline in performance. However when clocked at 3.0GHz and beyond, the Phenom II X4 really picked up the pace, and in many cases was able to outclass the Core i7.
In games such as Wolfenstein, Call of Duty: Modern Warfare 2, Tom Clancy’s H.A.W.X, BattleForge and Far Cry 2 the Phenom II X4 processors were actually faster when clocked up near 4GHz! This is quite amazing as out of the 9 games tested, the Phenom II X4 series was faster than the Core i7’s in 5 of them. Although the margins were very limited, the Phenom II X4 was found to be faster, and even if had it just managed to match the Core i7 series with the Radeon HD 5970, we would have been impressed.
While the Phenom II X4 matched the Core i7 in Crysis Warhead, the only games where it failed was Company of Heroes Opposing Fronts AMD-102FPS Intel-109FPS, Left 4 Dead 2 AMD-130FPS Intel-134FPS and Batman Arkham Asylum AMD-159FPS Intel-169FPS. The Phenom II X4 was noticeably slower in these games, making the Core i7 the better choice here. Still, for the most part we found the Phenom II X4 to be every bit as good as the Core i7 processors when gaming with the new Radeon HD 5970.
Having said that, we recommend that AMD users looking at buying this powerful graphics card make sure that they have a Phenom II X4 processor that is clocked at 3.0GHz or greater. Most Phenom II X4 processors are capable of overclocking to 3.0GHz and beyond, while the more high-end options, such as the Phenom II X4 955 and 965 processors, come clocked at 3.2GHz and 3.4GHz respectively.
While we hardly expect there will be many users trying to pair a $600 US graphics card, such as the Radeon HD 5970, with a budget processor, it is nice to see that the sub-$200 US processors are up to the task. The Intel Core i7 920 proved to be more than powerful enough at $280 US, while the AMD Phenom II X4 955 will work just as well at $165 US, giving users plenty of great options.
Compared to previous CPU scaling articles a few things have changed this time round. In the past we have set out to find what kind of CPU is required to power the latest and greatest graphics cards. We would test the graphics card or graphics cards in question using the highest possible visual quality settings with maximum AA/AF quality enabled. This places much of the work on the graphics card and portrayed the GPU as being the system bottleneck when using high-performance CPUs.
The idea was to determine if a Core 2 Duo processor could deliver the same gaming performance with the Radeon HD 5970 graphics card as the mighty Core i7, and if so, at what operating frequency would the two meet. Such an article is useful for readers who are looking to upgrade their graphics card, but wish to know if their current CPU is powerful enough to take full advantage of the upgrade.
However this time around we are testing a pair of Radeon HD 5870 graphics cards without enabling any AA/AF quality settings. Furthermore, we are not just testing at 2560x1600, and will instead include a low resolution test using 1680x1050. This will allow the high-end processors to really stretch their legs, and will uncover which processor would provide the best performance assuming no limits.
That said, these results will not necessarily reveal which processor is required to power a pair of Radeon HD 5870 graphics cards running in Crossfire mode. This is because the cards are not being pushed as hard as they could be given that AA/AF is disabled. Therefore, while our previous testing methodology may not have shown much of a difference in performance between a Core i7 processor operating at 3.6GHz and 4.0GHz for example, these non-GPU limited results that you are about to see likely will show quite a significant difference.
Something else worth noting is the fact that we will not only be including the results for the average frame rate, but also the minimum recorded frame rate. This is not something we have done before when running so many tests, as it is quite difficult to get accurate minimum frame rates.
For example, when testing with Company of Heroes with the Core i7 processor at 4.0GHz, we saw a consistent average frame rate of 155fps at 2560x1600. This frame rate would never deviate more than 1-2fps up or down. However the minimum frame rate would fluctuate between 40–80fps, making it difficult to accurately record this data.
Occasionally we would get a result as low as 2fps which we decided to ignore as this quick drop in frame rate was likely caused by something else happening in the background. In the end we decided that the only way to accurately show the minimum frame rate was to take the average of six runs. Typically we take the average from three runs, which is quite time consuming in itself. Still, this was not enough to accurately record the minimum frame rate and we were forced to double our work load.
a) You keep on insisting on going back bout the OP using 8xAA, when later people were simply replying to him about his question regarding the CPU.1) Still both fail would make no difference to the OP at 8XAA.
2) That's depends on how much spare there is & if its so close to the bone then it would impact the faster CPU before it impacts the slower because the CPU faster was closer to the bone of the GPU max to begin with.
3) It depends on what level the minimums are & how long the minimums lasted to whether they became an important factor.
Most of the time my mins are 60fps my avg 60fps my max 60fps maxed out on most games i play, there are people with i5/i7 that don't get that because they are on much weaker GPUs.
My GPUs are more powerful than these & im CPU bottlenecked so i turn up the quality but i hold 60fps Vsync so everything that's over 60fps means squat to me.
http://www.techpowerup.com/reviews/ASUS/ARES_CrossFire/1.html
Added
Even with the games which said was noticeably slower, no one would notice that out side of a FPS counter at those high FPS anyway.
And from the review which you keep quoting from.
Which is what most people aim for.
Which is my point that with AA/AF the difference becomes less.
And as i said its all about the averages & not about mins in a few games here & there that scale badly.
And personally i find the averages that many people accept in games in general appalling but that is their preference/choice/circumstance.
You just assume everyone already knows that; lets say I'm pointing out the obvious...does it matter when what I say is true? Like if there are people saying 5870 is faster than 6870 again and again, I suppose you would say they shouldn't bother pointing out the "obvious" since "we already know".We already know all of us & like i said in the other thread as well that Intel is faster we all know as well that Intel will give higher minimums but again you fail to understand that its the averages that matter & once it reaches a level that the user is happy with then that's all that matters.
