Which cable
17 May 2011
I have a 20" samsung pebble and planning to buy radeon hd 5830. I believe it has hdmi, displayport and dvi connections. So which type of cable should i buy for best picture quality? I intend to use it for gaming.
I would say its down to personal preference, I myself would probably go for the HDMI to mini HDMI cable.
Saves messing about with silly screws, if you do need to remove the cable for something
Personally I'd say DVI, purely as it has the screw-in connector, saves things coming loose!
Totally opposite opinions there :p
Use whatever cable you have, if you need to buy one then I'd use DVI personally.
