Ok, so a quick update for you. Cant remember what happened last night, if I recall the machine crashed for some reason and I opted to let Windows attempt a repair when given the option on boot. Wnd forward a few mins and Windows tells me it is unable to do a repair, and then wont boot and comes up with anothr BSOD.
Hi mate, i dont want to off your original topic too much, but i think i have been suffering a similar problem to yourself.
I built a system last year with the following spec:
I7 950
Gigabyte ga-x58a-ud3r
6 GB Corsair XMS 3
(This was one of the pre-overclocked bundles from Overclockers)
Gigabyte Nvidia GTX 580
WD Raptor 74 GB O/S Drive
Seagate Barracuda 1.5 TB Storage drive
XFX 800 Watt PSU
Windows 7 64 Professional
Whilst playing Arma 2 last week, the system suddenly rebooted after a BSOD, then entered startup repair, and did this 3 times before finally saying this computer coud not be repaired automatically, so i was basically left with a dead machine at that point.
After a complete format and re-install of Windows 7, the system ran ok for 2 days, then one morning when i went to turn the system on after using it and shutting down normally the previous night, it entered the repair loop again.
I then reinstalled Windows 7 again, but this time i replaced my 6 year old WD Raptor 74 operating system drive with a new Hitachi deskstar as i was suspecting the old drive was possibly nearing the end of its useable life, and causing errors and data corruption.
After 2 days using the system with the new Hitachi unit, the pc suffered anothe BSOD crash, and yet again entered the startup repair loop. I have however found a solution to fixing the system and allowing me to get Windows working again without having to carry out a ful re-install, but for the love of me cannot figure out what is causing the crash and boot up issue in the first place.
I may create a thread on this of my own, but if you like i can give u the fix for the startup repair loop to save u having to re-format again, as in y case it does not solve the problem.
