just pulled the trigger on a gtx 580
25 Mar 2003
Scotland
Just bought a gtx 580, hopefully make it to mine on Wednesday. Going to have to keep this one from the missus...
Never spend this much on a graphics card before, usually I go for around the £250 mark not £350 eek...
Tell me I haven't done wrong! please!
You spent £350 on a gpu! what a waist :p
I look at my sig, been running one since Jan and pretty happy with it, using a Inno3D which was part of the Ocuk brand range :D
I warned you...
Opteron 170 @ 2.7Ghz
4GB pc3200 running @225Mhz
Asus A8n32-SLI Deluxe
8800 GTS 512
Got a Seasonic x750 though so it should be up to the job :)
I know, it's very old :(
Slight bottle neck :eek: :p
Bulldozer is around the corner ;)
And let us guess a 19" monitor?
Nope got my Dell 2407 WFP :)
My rig felt a big sluggish while playing The Witcher 2 so I thought I would upgrade the graphics card then the rest of the machine once I have a little more spare cash.
I SERIOUSLY hope you are joking...if not, you gonna upgrade the rest of your system soon?
Nope not joking, I have resisted the upgrade itch for aaaages. Had a new job for a bit so now I can afford to buy some presents for myself.
I'm building my brother a PC around an i5 2500k so I'll try my 580 in his new machine and see what I'm missing out on.
Was debating whether to go for a 570 or 580 but I though sod it, I might as well get the best I can get now and not worry about whether I've should have bought the more expensive one.
You bought it now so its too late. But..
First your rig needs major updating before you graphics but you go and spend a relatively insane amount of graphics creating a needless bottleneck.
Secondly, you should be happy you got to best now but the price difference between a GTX570 and GTX580 is larger than the performance difference. The difference is not worth the extra.
Happy?:p
