1.Do you have a external storage for your videos?You do need a lot of space especially if you are shooting in HD and burning in Bluray.
2.I would not advice playing any kind of computer games on a professional system...
Well if were going for a GTX590 + 2600K thrn you'll want at the very minimum a 120.4 Rad or 2 x 120.2's... If your going for either super silence or heavy overclocks you'll want 2 x 120.3's
Here's want I'd suggest for watercooling.
Radiator (s) EK CoolStream XT 360mm Triple Radiator : XT 360 £48 x 2 (£96)
Pump + Res: Laing DDC1+ Ultra Pump 600 L/hr with XSPC Reservoir Top (£80)
CPU Block: Watercool Heatkiller LT Rev 3 CPU Waterblock for Intel 1155 (£40)
GPU Block: EK FC590 GTX Full Cover Waterblock for NVIDIA 590 GTX Graphics Card (£100)
Fittings: EK PSC 1/4" Thread Compression Fitting for 1/2" ID - 3/4" OD Tubing : Black (£3 x 8 = £24) + Bitspower 1/4" Thread Rotary 45 Degree Fitting Matt Black (£4 x 4 = £16)
Tubing: XSPC 1/2" ID - 3/4" OD (13-19mm) High Flex Tubing (£3 x 2 =£6) 2 Metres
Fluid/Coolant Feser Aqua Cooling Fluid (bi-distilled) (£5) + Petra's Tech PT Nuke Concentrated Biocide (£3.50)
Fans: Scythe Kaze Jyuni Slipstream 120mm Fan 1200 RPM (£7 x 6 = £42)
Total: 412.50
Watercooling done right.
Ib_compl3xity, you should spec a build for her! (I don't know anything about watercooling) then u can build it for her too since u offered and also because u obviously know your stuff xD.
Does he? What case are you going to stick two 360 radiators in? Not only that, those EK radiators aren't that brilliant in comparison to others on the market, and 18W DDCs are not the quietest of things, which is only exacerbated by the XSPC top. On top of this, a silver kill coil would be better than PT Nuke, and why pay for Feser water when you can get distilled much cheaper from the chemists.
And one last thing, a GTX590 is a waste of money vs 2 6970s with waterblocks for the same money, or 2 GTX480s with waterblocks for less.
Snip
Snip .
