** EPIC TUESDAY @ OCUK ** Roccat Kave 5.1 Headset (LIMITED QUANTITY) £59.99!!!!! & More ***SOLD OU
22 Aug 2010
Hear clear with our headset deals on EPIC TUESDAY @ OcUK! There are very limited units but at this fantastic price you can not miss it.
ONE UNIT PER CUSTOMER. I HAVE MORE THAN ONE IN STOCK SO PLENTY TO GO AROUND. THE DEAL WONT LAST FOR ONLY 2 MINUTES EITHER ;)
Roccat Kave 5.1 Surround Sound Headset @ £59.99 inc VAT
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels.
- Real 5.1 Surround sound with speakers aligned at a 12° angle
- Microphone with mute LED fully rotatable and completely removable
- Tip’N’Control desktop remote for central management of all volume functions
- Dual sound-profile with movie and game settings
- Solid aluminium hinges enabling heavy duty use
- Hand-sewn comfortable earcups featuring external noise cancelling
- Adjustable vibration unit for a realistic gaming experience
- Headband with three pads for equal weight distribution
- Easy to carry folding and compact design
Was £67.98 Inc. VAT
Only SOLD OUT inc VAT.
ORDER NOW
Plantronics GameCom 367 Gaming Headset (79732-05) @ £SOLD OUT
The closed-ear GameCom 367 gaming headset delivers an immersive audio experience with 60mm stereo speakers and specially designed earpods that redistribute pressure for maximum comfort. When you’re ready to fire off orders, unveil the hidden, noise-canceling mic boom to strategize clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic mute controls. When you’re done, rotate and tuck the mic boom inside the headset - then let your score do the talking. This Plantronics headset is rugged, military-like design and extra-strength cables keep your hardware hardcore - game after game after game.
- Closed-ear headset delivers an immersive audio experience.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-like design and extra-strength cables make your hardware hardcore.
Was £21.99 Inc. VAT
ORDER NOW
Arctic Sound P281 Professional headphones @ £16.99 inc VAT
The ARCTIC SOUND P281 is a pair of DJ headset that combines stylish appearance, durability and practicability in an affordable package, made to meet the specific requirements of professional DJs. The ARCTIC SOUND P281 contains a 50mm drive to ensure high-fidelity sound and is constructed with ergonomic features for long hours of usage.
The ARCTIC SOUND P281 has an adjustable and padded headband to provide excellent listening comfort. Leather lining and soft cushion on the earcups provide secure fit and allow the headset to rest comfortably over the ears. Upper headband is made of artificial leather lining to emphasize its stylish appearance, while the underside headband contains netted nylon for sweat absorbing. Its circumaural design wraps firmly over the ears and provides a high level of noise isolation. Hence, this tightly closed and highly insulated structure captures delicate sounds for DJ in noisy ambient settings.
As a DJ headset, the ARCTIC SOUND P281 is designed for music and sound monitoring. The headset can be bent and flexed in many ways. Its 90-degree swivel mechanism on both earcups allows DJs to have the flexibility for single-sided monitoring. The folding design in the ARCTIC SOUND P281 has flexible joints, allowing DJs to fold the headset to half its size for space-saving, travel, and protection. Coiled cable on the headset is heavy and sturdy to prevent excess cable from sitting on the floor or DJ table.
- Superior output power
- Extra-wide frequency response
- Lightweight and comfortable
- Designed for DJs
- Adjustable headband with 90-degree swivel earcups
- Gold-plated standard 3.5mm plug with 6.3mm adapter for wide compatibility
- 2 Years warranty
Was £18.99 Inc. VAT
ORDER NOW
I have the Plantronic ones. They are a steal for that price. Only problem i have with them is they don't hold sound in as well as they block it out.
Damn, was tempted by the Kave, went to lunch to think about it, decided on it, come back and its now gone! :(
Oh well, here is to hoping it will be on Today Only someday soon.
