- 16 Feb 2010
- North East England
...The MSI guy also claims that it unlocks to the 6970 so that should tell you the real value of this bargain![]()
Thought only reference rev. 1's unlocked?
Does that 6950 have the dual bios? if not flashing it can be hazardous, if your not really sure what your doing anyway....![]()
Will you flash it then? What sort of idle temps you getting?
By the way, have you got a fan on the side panel of your 690II?
Bah, nothing short of what I would advice to anyone
I know how to use Anandtech Bench tool, I even posted it on this Forum almost a year ago
I also expect the card to depreciate in price but still want to have something that will hold the most value out of the lot in 6 months.
Thanks for the suggestions, doesn't seem like anything is of any great interest to me.
I'll have a look for a good deal on the 6950 that can be flashed to a 6970.
There were some deals on GTX480s close to £180 not long ago.
HD6870s in Crossfire look like an option too, if I can find them relatively cheap.
EDIT:
Radeon 6870 x2 - £260
GeForce GTX570 - £230
Radeon 6870 x2 - £230
GeForce GTX480 - £200
Radeon 6950 2GB - £190
Radeon 6950 1GB - £170
How do I find out which 6950s unlock to 6970s?
If you are considering 6870 cf, why not look at 5850 cf, I should think it is better.
Did you try the full bios flash? It should unlock the shaders as well if you do, thats not the prob, some cards cant handle it and have probs once done but they all can do it? mines flashed, not overclocked running at 1375mhz and 880mhz without any overclocking other than the flash. Did you follow all the instructions when flashing there are really good step by step guides online.
The reason I asked is because until couple days ago, I have always had the fan on the side panel as intake; I've change the fan from intake to exhaust as experiment, and the GPU temp dropped by a few degrees under load.Yes, sucking the cold air in. Only the stock front intake and back exhaust fans besides it.
The reason I asked is because until couple days ago, I have always had the fan on the side panel as intake; I've change the fan from intake to exhaust, but GPU temp dropped by a few degrees.
I think the reason for this is because of how graphic cards with "dump heat into case" type cooler, getting rid of the heat in the case around the graphic card area is actually more efficent at lowering the GPU temp than bringing in cool air blowing the heat all over the place. You could try swapping it around and compare the temp before and after.
P.S. I do have a fan at bottom middle as extra air-intake, and another fan on the drive cage blow toward the graphic card from front to rear.
