So after weeks of technicians attempting and failing to fix my tv Oncall have finally decided to swap it out, only they don't have my model any longer so I'm left with the refunding the cost of £500 and having to spend it in store. Now I'm not overly bothered by this apart from my lack of ability to make a choice
Went down today and had a look around and other than the new expensive ones the only tv that caught my eye was the panasonic TX-42U30B Plasma, at 42 inches it's significantly bigger than my current sick LCD which has me concerned.
I sit roughtly 9 feet away from my tv and that's as far as I can get, is 42 inches too big for that distance?
Also, being plasma I assume that I'll get far better colour and blacks that the current LCD which is a TX-L32S20B?
Current TV:
http://www.panasonic.co.uk/html/en_...20B/Overview/3788571/index.html?view=&angle=3
Proposed TV:
http://www.panasonic.co.uk/html/en_...ecification/7048306/index.html?trackInfo=true
I'm pretty happy with the current set, just the issue it's having is a bugbear and the only way to minimise it is with maximum intelligent frame creation turned on which I cannot stand. I'd also love to have some better blacks and assume the plasma would supply this?
Thanks in advance
This is what my current setup looks like:
Current TV:
Proposed TV:
Thanks in advance
